Alien Dvr Problem
MISHPET
There are 2 different tings here MISHPET
I think you are talking about your external Static IP address, ie your public internet address or WAN address. Im assuming you have that (its your 81.x.x.x address)
You then port forward in your router to your dvr (on the 192.x.x.x address)
But if the dvr is changing its address on the internal network the port forwards will fail as the router will be forwarding to the wrong internal address.
Depends on the router, the BT Homehubs and 2Wires forward to a device instead of an address
