Eurosec Cp8L Pgm1 Question......
DaveDesign
Evening all,
Got a question for you....
I'm adding a honeywell informa dialler to my CP8L. I plan to connect to PGM1 and program as alarm.
My question is if anyone knows if PGM1 will be 0V or positive on activation. A quick scan on the installation manual and i couldnt find that out. I assume positive but would like to double check as the informa can be progammed as positive or negative inputs.
Many thanks in advance guys
Dave
Found this but might as well be spanish to me!!!!
PGM 1
PGM1 terminals are an open collector output held at 12V
through an integral 1k resistor. Max current sink into PGM
1 terminals is 50mA.
Does that confirm that it sits at 12v and then drops to 0v on activation??
cheers
Thanks James that ace.
I take it the resistive pull up is to keep it at 12v and stop it wandering higher?
Just for info!!
You can use pgm but I would wire into bell trigger on the panel to dial out but both is ok
I was going to use bell trigger if i could'nt sus out pgm1, But thinking about it bell might be a better option as it will also dial if the alarm is trigger by panic or any other event.
I will see if i can figure out if the bell trigger goes high or low.
All done and working :proud:
Thanks for the help and info.
The only thing i don't like about the informa is that it starts playing the message before the call is even answered!
