evosan Posted July 15, 2012 Posted July 15, 2012 I have a reason 8 bell box and every 10-15 seconds I geta curping noise anyone had this before
MrHappy Posted July 15, 2012 Posted July 15, 2012 no, never touched one TBH I would assume nicad not connected / fault ? Mr Veritas God
sixwheeledbeast Posted July 15, 2012 Posted July 15, 2012 If you watch it outside are the status LED's correct? Have you checked your wiring? Is the battery on as above? Front spring tamper located OK? Is the bell showing a fault on the CP? You could remove all the wires execpt the hold off (pos/neg) to see if the panel is triggering it.
Adi Posted July 15, 2012 Posted July 15, 2012 you could remove all the wires and bin it. I really can't be ar**** with it anymore.
