Two Camera & Dvr System With 40M Night Vision
Hi All & Hello
Newbie here
My question is , i want to set up a 2 camera system with night vision to 40m ,
should i go down the maplin route
or will i get a better system for my monies if i buy separate
Budget of around £500.00
Thanks pete
Hi Pete Welcome to the forum
Swerve maplin like your life depended on it, most of there cameras have plastic lenses that warp in the sun. the kit is cheap and nasty.
You would struggle to get 40 meters ir for your budget, £500 gets one decent light, no camera, no dvr. Most of the cheap IR cameras say upto 30 meters IR I havent seen one that does anywhere near 30 meters, 20 meters max and then its not that good.
There are plenty of budget companies out there, I would avoid buying from Ebay or Maplins. I only buy from trade suppliers and wouldnt buy in your budget range so cant really tell you the good from the bad in budget country
Someone will come along and recomend somwhere though
By the way please dont post the same questions in different areas of the forum thanks
