Galaxy 96 Prox Tags
LastChance
Hi.
I've got a galaxy 96, 6 keypads and 40 odd fobs. I can, and have programmed them into panel. They will however not set system. Programmed in users as timed set, but I'm sure there is something I need to do with the max keypad option to get these to work.
Any advice welcome
Okay, so you set 42.1 (select user) then 08 (MAX Function) and set to 12 (timed set if that's what you want the tag to do) ?
Then hold the tag in front of the keyprox for a few seconds (not just a quick swipe). It will double-beep and start setting.
Its keyprox or max readers? If keyprox did you hold the 2 keys or just type the number in.
Group mode enabled? Does it arm on the code?
arms on code, group mode is enabled. keyprox keypads, 2 on branch 1, 3 on branch 2.
all allow setting via code. fobs added by pressing 1 and A at same time. Prox Tag address fills field, double checked by trying to add same fob in users 1 and 2, tells me that fob is already used.
tried multiple fobs incase fob was faulty.
this has got me stumped!!!
