Ademco Accord Xpc 2 X Pir On 1 Zone
Hi all
I know its not recommended but i need to double up 2 pir's onto 1 zone, no more zones in panel and these two sensors are literally back to back pointing either way of long corridor.
The panel is accord xpc and activ8 pir's, using double end of line resistor circuitry for zones
Is this possible to double up ? if so hows it wired
thanks
Yes your are right just crack on and double up, better still wire them in parallel to reduce fa's
Cruel! But the clue to resolve is in the answer.
Customers!
You may think its over kill but when you have a fa on that zone are you gonna replace both detectors. IIRC the XPC has a 9th zone on the RKP have you used that?
not interested whether its morally correct or incorrect or not the done thing.
i just know how i would like my system to work
and would like to know whether anyone can help achieve this with some helpful info, cos thats what forums are made for..
just want to use two pirs on one double end of line zone, ademco uses 2 x 1k resistors by the way.
Can i achieve this? my ultimate goal.
thanks
Sorry to be harsh but why should we be interested.
You have been told how to do it, politely and helpfully.
Your best option is to use the keypad zone if available.
