Accenta G4 & Adt Bellbox
steq184
Hi I have an Accenta G4 panel connected up to the yellow ADT bellbox, system is about 9 months old and has works perfectly up to now.
Now find that the bellbox does not sound or strobe even when testing through the alrm test feature on the panel.
No wiring has been changed since first install.
Any ideas what the problem could be???
Any expert advice would be very appreciated.
Thankyou Steve
Can you set the system? when you're going through the walk test does the internal speaker sound? Was it installed by ADT?
