Accenta 8 Mini Problem
hi All,
New to the forum, hope the following makes sense.
WE have an Accenta 8 mini security system, and I have a problem with it. Ever since we had some new lounge carpet about 8 weeks ago, sometimes when I tread on the retaining strip by the door (under which I think the Accenta wiring to the lounge windows is situated) I get a single 'beep' and the control panel shows a single asterisk, as though I'd started entering the code to arm the system.
It's easy enough to sort out - press reset on the panel - but it shouldn't be doing this, and I wonder if anyone else has had this, and if they have, how did they sort it out?
Many thanks in advance for any help provided.
cheers,
Simon
