alterEGO Posted September 12, 2012 Posted September 12, 2012 How many standard detectors does everybody stock? We have a G2 DT & Quad and G3 DT & Quad. Same wired detection for both domestic & commercial.
Oxo Posted September 12, 2012 Posted September 12, 2012 I have some although stock levels are like my hair.........................short b4 the team leaders jump in But 3 main and two others for a direct no decor replacement.
antinode Posted September 12, 2012 Posted September 12, 2012 G2 quad and G3 DT. Keeps things simple and stock levels minimal. We're using the Bosch Blueline Gen 2 Quad and the Guardall DT15+. Best combination of detectors we've used, especially since Bosch re-designed the Blueline range into a smaller casing. Trade Member
Oxo Posted September 12, 2012 Posted September 12, 2012 I like those you use, neat and tidy kit with room to sling a truck inside Seriously, I do like em.
Ronnie Posted September 13, 2012 Posted September 13, 2012 iWise quads, DT's & quadsec for domestic and commercial. We only use these at grades 2 & 3, much easier to manage.
alterEGO Posted September 13, 2012 Posted September 13, 2012 Ronnie, is that the horribble confirmation detector? The one thats no good if you can't install it on the wall with the entry point?
jb-eye Posted September 13, 2012 Posted September 13, 2012 iWise quads, DT's & quadsec for domestic and commercial. We only use these at grades 2 & 3, much easier to manage. As above although we have used the quadsec our stock box only has the iWise and the pyronix TMD detectors.To Bump in, i TODAY found that the SC550 has once again been labeled G1. Spoke with CQR and they said they have been incorrectly labeled thus still G2. Customers!
Cubit Posted September 13, 2012 Posted September 13, 2012 TODAY found that the SC550 has once again been labeled G1. Spoke with CQR and they said they have been incorrectly labeled thus still G2. Nice to see ISO processes working eh?? not.
jb-eye Posted September 13, 2012 Posted September 13, 2012 Nice to see ISO processes working eh?? not. Not having a label would be failing. Nowt wrong with a little bit of non conformance to show the system works. Seriously ISO used to be a PITA, bit like H&S gone mad. These days its so simplified having it or not, on the most part is just the audit. Most do the procedures without knowing or bothering to formalise. Customers!
Cubit Posted September 15, 2012 Posted September 15, 2012 Not having a label would be failing. Nowt wrong with a little bit of non conformance to show the system works. Seriously ISO used to be a PITA, bit like H&S gone mad. These days its so simplified having it or not, on the most part is just the audit. Most do the procedures without knowing or bothering to formalise. Not strictly true. They issued kit, incorrectly labelled and from your comment it seems you informed them they were wrong. If ISO was working correctly, unless you were the 1st to notice, they should be informing you, the customer/distributor etc
