Auto-Dialer-Tg-911
Unless they have updated the SD1, don't get that one, get the SD1+.
The difference, if power is removed, the SD1 looses its programming, the SD1+ does not.
They had sent me a replacement which also does not call out :/ This one seems to remember its settings on power off though..
I suppose you need to send that one back too?
As above they dont make the sd1 anymore, i was meaning a plus
Yh, Ive tried everything to get it to call out to any number which has proved a failure, have you had one? If so how did you set it up?
no mate, i wouldnt touch anything like that
If anyone else has an idea how these things work please send me a message, at the moment they seem a waste of money, you would of thought they would have tested them here first.
Its made in china as cheap as possible. You cant really send it back and can use the language barrier to pretend to support it.
If it actually works is probably well down on the list of requirements
Yh, They provide support they does not make sence, I mean read the manual just seems like random ****... I give-up on the thing and going to claim my money back as far as im concerned this item is faulty.
SD1+ you have been told already.
What you have is a cheap imitatation that even has the spelling wrong on the unit.
