Securit 700L Keypads
vectradam
If I use the engineer code, will this allow me to remove the keypad without setting off the exterior sounder?
£40. I've got to hand it to you. You are getting more for that old tat than it would cost for a new panel and keypad.
Can Mr DIY swap and replace a panel easily? Why bother when they can replace the keypad in 5 minutes and no engineer cost.
Sold between 70-100 since November.
See your point although if I moved into a place with that tat installed it would be in the skip before I unpacked anything.
Guessing you have a couple of ID's then?
