Alarm For Garden Office? Design Help!
garnayrob
Hi all,
I'm looking for some advice on alarm system design for my 10x8 garden office (timber) with 2 glass opening windows and an opening door (also with glass). I know a bit about alarms and happy to install, just want some clarification.
Looking to install 1 x dual tech PIR (to cope with heat imbalance when sun is on windows). How would this work being the only zone? I'm not intending on adding any other sensors as I beleive the PIR will provide all the protection needed.
Can you have a 1 zone PIR alarm system? Not quite sure what systems would support this - I guess I'd need a short entry delay. Ideally would be great to disarm remotely, but want a fairly professional solution and not a Yale style DIY kit.
Budget of up to £200 - also want internal and external sounder.
What is the best kit for the job?
cheers
Rob.
Personally I'd put a contact on the entry door. Then you can delay the dual tec only after door opening
Disarming from a remote will need a high end panel which you really don't need
As its diy I'd use
Control panel honeywell optima compact
Dualtech honeywell dt 7550 or 7450
Door contact knight or cqr grade 1 surface
Sounder whatever you want
Another one perhaps for your James! Just need some guidance on wiring the DT7550 to the ADE Gen 4 panel before I power up. On the PIR I have wired up as follows to the panel - please correct me if wrong.
TBL = n/a
TBL = n/a
T1 = TAMP
T2 = TAMP
EOL = n/a
C = Zone 2
Test = n/a
NC = Zone 2
V- = 0V
V+ = +13v
Is this correct? Also do any of the jumper or dip switch settings need changing from default?
Currently:
FAULT (RF) = F (EOL 3K)
TAMPER (RT) = A (EOL 1K)
ALARM (RA) = A (EOL 1K)
Dip Switch 1 = ON (High Sensitivity)
Dip Switch 2 = ON (LED Enabled)
Dip Switch 3 = ON (Anti-mask Reset 1 Alarm).
Thanks for your help :)
cheers
Rob.
Wiring looks correct.
The dip switches can be left.
The jumpers will need setting for double pole (no resistors).
I haven't got information handy but this will probably be no jumpers installed.
Not sure I'd leave it on high sens, needs walk testing first to ensure correct coverage
cheers guys, much appreciated. Disabiling the integrated EOL resistors is all jumpers off - so I shall remove them.
Enjoy the rest of your weekend and wishing you a good start to the week :)
Guys, quick help if possible - I've wired everything up however the external siren keeps sounding even with cover on (tamper switch active) and control panel powered up.
I've wired up as follows from siren to panel, is anything wrong?
STROBE+ on panel = n/a on siren
STROBE- on panel = ST on siren
SCT(T) on panel = R on siren
SCB(A) on panel = V- on siren
BEK+ on panel = V+ on siren
Bell - on panel = SW on siren
