Need Help On Networking Cctv
Hi im new on here been installing cctv equipment for a few tears now , recently installed a swann dvr 8-1200 (cusomers choice ) dvr is working fine connected to network but every now and again router keeps disabling firewall options wich stops it viewing through iphone and net . customer is useing a belkin wireless g router when u go on router settings its unenabled its self ! click enable and its fine for a few days . Just wondering if any 1 else has come across this problem Thanks
I doubt anyone here would of touched Maplin toot
Belkin = pants
QFA - never liked belkin routers
You could try (if possible) to put the cameras IP on a DMZ
It definately not to do with the CCTV system anyway.
Hi thanks for replys i insisted on a different dvr but customer wanted this cheap option from maplin lol . i know the dvr works fine its just with the router wich was already installed on premises . im gonna try a different router to see if problem still persists Wich routers do you use ? . Thanks again
Netgear, Dlink, Cisco, or Draytek
Hope you told him it will make all his hair fall out and his teeth go curly
