Help!!!
Guest Akeem
Dear all,
Kindly direct me to where I can get online a guide to troublehooting CCTV system and even other security equipment like Access Control, Fire and Burglar alarm
Thanks.
Akeem
I'd suggest the best bet is to go to the manufacturers website of the kit your working on because, as far as i'm aware, a 'guide' like you are after will not be available as each brand of system will have it's own 'guide'.
I would add that even if you were to follow such a 'guide', if you do not have sound electrical/engineering knowledge, you will not understand what you're testing for, why you're testing it and what the results mean.
This, I'm afraid, comes only with time and experience.
:0)
If you don't know......ask.
You could try Tavcom training, also for interactive courses and books.
Other than what Brian has mentioned, theres always this forum.
