Alarm Master Wont Conect To Word 2007
sle101
Ok so all of a sudden , for reasons i cant explain... Alarm master suddenly wont connect to word 2007
From contracts if i click documents then new document im getting errors such as "bad Parameter"
or an error such as Ole error 800A1704,
Also if i go to contracts then documents - Letters + documents - and try and run lets say a standard maint reminder ,
i get the error "Requested object is not available"
Anyone else had this or know a work around. Worked fine yesterday.
cheers
Lee
Top tech tip of the day....
I assume restarting the pc will fix it ?
Sound daft but we used to get these issues if one of the desktops had not been restarted for a few days. Failing that call PCData on Monday, maybe another one of their little tricks like extending table sizes bit by bit.
used to have to rebuild the tables (not done that in long while?)
when I had a single doc that would not merge, I renamed one that worked & cut & pasted the non working one on to it....
