Honeywell Optima Compact Fault
samauty
Ok all the links are back in and I ve put a link between the SAB terminals T and A (you were right :) ).
The alarm is still not unlocking after power up. After 'user reset' following putting the panel back on, the 'tool' LED is flashing and the "SOS' LED is on permanently.
Any thoughts?
Cheeers !
Ah no, nothing other than the links are connected on the tamper circuits. The PIRs and contacts are only connected to the zones (i.e zone 1 + 2 contacts), (3+4 for PIRs + supply power). All the other zones (5-8) are linked out.
Could there still be a voltage issue?
TRY IT LIKE THIS, TAKE EVERYTHING OUT.
E V E R Y T H I N G
CONNECT ONLY O N L Y THE KEYPAD
YOU ARE TRYING TO PROVE THE PANEL, SO IT NEEDS EVERYTHING DISCONNECTED.
PUT THE KEYPAD ON A SHORT FLYLEAD, THAT YOU KNOW IS NOT DAMAGED.
Do you think I said this twice before because I have nothing better to do??
it does sound like the board may be goosed but as oxo say its best to try with everything dissed. If its an optima then also drop the keypads and just see if it works with nowt connected. and all links in place. If it dont then its gone. But id be suprised they have a very low failure rate
It doesn't have a keypad, its built in, but you what tomorrow, I might just take everything out....
cheers mate !
