I Am Using Intellex Lt Can Anybody Tell Me How To
halsaps
Hi
I am using Intellex LT can anybody tell me how to set up a second user as to access a new camera
i have added it says I needed to have 2 users logged in not completley sure why . Help v v much appreciated.
Hi
2 users logged in??
New one on me.
What can be confusing is the icon/button says log in. When you log in as a different user, it logs the previous user out.
2 users logged in??
New one on me.
Yes I don't know quite why but it says s second user needs to log on and as I the administrator know I thought i would
be able to acces everything thanks for replying anyway
You're not trying to setup coverts are you?
Also, is this a brand new machine?
You're not trying to setup coverts are you? no just trying to access a new camera
no been in the store for nearly a year I have just re-set me as an administrator but know need to create a second user for some extra features that say need a 2 man log in don't know why
You've got the 2 man rule enabled then.
Try creating a second admin account.
Administrator2
4321
You could also try disabling it.
Go to setup/advanced.
Not seen this feature enabled before. If the above fails i'd be tempted to go into the intellex config and see if you can disable it from there.
Administrator2
4321
thanks i'll try that
