tank_fv101 Posted September 14, 2012 Share Posted September 14, 2012 Hello everyone, I'm currently using a Dedicated Micros Sprite 2 (old rounded version), and I am about to receive a secondhand new version. What I am stuck on is how to connect my PTZ cameras. Forgive my lack of knowledge of the technical terms, as this is for a home system! I've tried to work it out with the DM Manuals, but my brain won't compute!!! As you'll probably know, the classic model allows you to connect the Bus wires for the PTZ in the green terminal block, but the new model only accepts the D Type connection. I'm guessing I'd need to buy a Male 9 pin D Type plug for Serials 3 & 4? So, should two wires originally from the green terminal block go to Serials 3 & 4 instead? Finally, which wires would go where? Currently I have.... Bus A: +=White -=Green Bus B +=Red -=Black I'm fine with knowing which number is which on the pins of the D Type. Many thanks for your help, as I just can't figure it out!!!! Chris. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33407-changing-from-classic-sprite-2-to-newer-version-but-need-help/ Share on other sites More sharing options...
tank_fv101 Posted September 14, 2012 Author Share Posted September 14, 2012 Sorry, I meant D Type Sockets, as per this item:- http://www.ebay.co.uk/itm/MODULAR-ADAPTOR-RJ45-9WAY-D-SOCKET-UNBRANDED-MHDA9-SMJ8-M-K-/390456134409?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item5ae8ffcb09 I was going to use it with the RJ45 cables as I've used Cat5e from the American Dynamics PTZ. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33407-changing-from-classic-sprite-2-to-newer-version-but-need-help/#findComment-290229 Share on other sites More sharing options...
breff Posted September 14, 2012 Share Posted September 14, 2012 Pins 1 and 9 IIRC The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33407-changing-from-classic-sprite-2-to-newer-version-but-need-help/#findComment-290234 Share on other sites More sharing options...
tank_fv101 Posted September 15, 2012 Author Share Posted September 15, 2012 Thanks for the fast reply. OK, I will use pins 1 and 9 in each serial port, but which wires (as shown above) should I put in each pin? ! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33407-changing-from-classic-sprite-2-to-newer-version-but-need-help/#findComment-290316 Share on other sites More sharing options...
Rulland Posted September 15, 2012 Share Posted September 15, 2012 The ones that work. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33407-changing-from-classic-sprite-2-to-newer-version-but-need-help/#findComment-290321 Share on other sites More sharing options...
fozzies Posted September 15, 2012 Share Posted September 15, 2012 Google "dm sprite pin out" Second item down, a pdf from dedicated micros, page11 in it Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33407-changing-from-classic-sprite-2-to-newer-version-but-need-help/#findComment-290322 Share on other sites More sharing options...
tank_fv101 Posted September 16, 2012 Author Share Posted September 16, 2012 The ones that work. Hilarious! Google "dm sprite pin out" Second item down, a pdf from dedicated micros, page11 in it Thanks very much. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33407-changing-from-classic-sprite-2-to-newer-version-but-need-help/#findComment-290401 Share on other sites More sharing options...
satsuma01 Posted September 30, 2012 Share Posted September 30, 2012 Hello everyone, I'm currently using a Dedicated Micros Sprite 2 (old rounded version), and I am about to receive a secondhand new version. What I am stuck on is how to connect my PTZ cameras. Forgive my lack of knowledge of the technical terms, as this is for a home system! I've tried to work it out with the DM Manuals, but my brain won't compute!!! As you'll probably know, the classic model allows you to connect the Bus wires for the PTZ in the green terminal block, but the new model only accepts the D Type connection. I'm guessing I'd need to buy a Male 9 pin D Type plug for Serials 3 & 4? So, should two wires originally from the green terminal block go to Serials 3 & 4 instead? Finally, which wires would go where? Currently I have.... Bus A: +=White -=Green Bus B +=Red -=Black I'm fine with knowing which number is which on the pins of the D Type. Many thanks for your help, as I just can't figure it out!!!! Chris. ftp://files155.cyberlynk.net/DS2ClassicManual.pdf here you go click link download the read manual for info you need "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33407-changing-from-classic-sprite-2-to-newer-version-but-need-help/#findComment-291167 Share on other sites More sharing options...
