Guest amc Posted August 18, 2004 Posted August 18, 2004 hi is there a maximum number of sensors that that you can have on one zone, i,e 6 vibration sensors thanks amc
Deltaseven Posted August 18, 2004 Posted August 18, 2004 It really is not worth taking shortcuts like putting more than one detector on a zone, unless you have absolutely no choice. As mentioned above, you must make sure that you use latching devices (so that you can tell which one has tripped). It makes it harder to track down a fault - even if the devices latch, if you have a cable fault or a bad join inside a detector you can spend ages tracking it down. If you must put more than one detector on a zone, make sure that you run sufficient cable to support the detectors (eg, if you are running 3 powered devices on one cable, the power cores must at least be doubled) (that goes for ID systems too - but from your question, I don't think that will affect you!) D7
Guest amc Posted August 19, 2004 Posted August 19, 2004 for three or four sensors on one circuit do you think doubling up of power core necessary Yes, 10.And PIRs / vibs must be latched. Contacts dont obviously. I think most installers now would take BS4737 as a minimum and not bother with the above, seeing as panels with loads of zones are so much cheeper than they were years ago. 20827[/snapback]
Service Engineer Posted August 19, 2004 Posted August 19, 2004 do you think doubling up of power core necessary That depends on the lenth of the cable run, and the quality of your cable. Most detectors dont use much current, usually between 10 and 15mA. ........................................................ Dave Partridge (Romec Service Engineer)
Guest pkh911 Posted October 14, 2004 Posted October 14, 2004 If your a decent engineer. RULE of THUMB 1 device 1 Circuit Then you have NO PROBLEMS should a fault occur
Guest Posted October 15, 2004 Posted October 15, 2004 If your a decent engineer.RULE of THUMB 1 device 1 Circuit Then you have NO PROBLEMS should a fault occur 27367[/snapback] This guy is full of wisdom
bellman Posted October 15, 2004 Posted October 15, 2004 If your a decent engineer.RULE of THUMB 1 device 1 Circuit Then you have NO PROBLEMS should a fault occur 27367[/snapback] Fully agree... makes the Service Eng's life much easier when things go wrong. Also in line with Richl, I double up the neg, especialy to data devices such as RKP's. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
