Accenta G3 Mini Problem
legend200578
Hi All,
I have an Accenta G3 Mini fitted in my house.
I had some new Front and Rear doors fitted yesterday and I disabled the 2 zones using the procedure in the engineers manual.
The problem is that now I am trying to re enable these zones using the procedure above but nothing happens and the zones are still disabled.
Procedure used
Prog
engineers code
5
1 (zone 1)
1 (security)
Reset
Reset
Reset
After doing this, the noise that is made sounds more like a negative Beep than a confirmation.
Any ideas?
Am I doing something wrong?
Any advice would be greatly appreciated
Don't think you got that progging sequence correct tbh, I'm looking now.
Do you get the same speaker sound on both zones when attempting to reprog?.
Try this (I am assuming that you wish to program the zones as entry/exit in full and part set....)
Prog
eng code
Prog (Zones 1, 2, 3 flash)
1 (Zone 1 light flashes and means you are programming zones onto Program 1 or Full Set)
1 (Ensure all zones you want active on the system are lit up. If not press number key appropriate to zone until all active zones are lit)
Reset (Zone 1 light flashes)
2 (Here you want to make sure that the zones for entry exit are lit, e.g.1 & 2)
3 (Here make sure that your entry route detector zones are lit up)
Reset (Zones 1, 2, 3 flash) Here you can press 2 and program a Part Set by following the same procedure as above...
Reset
Now press 5 and go through the procedure you outlined above to program the individual zones to security.
You should find that sorts it.
