New upvc windows and cable
Guest Daznsaz
Guest Daznsaz
Hi
I am about to fit my second alarm this weekend for my Father in-law, they have brand new upvc windows, i need to fit a wireless contact plus a wired aux magnetis contact to each window. Is there a reliable way of doing this without using screws and what would be the neatest way of attaching the cable.
Many Thanks in advance.
Hi
20878[/snapback]
check the warranty on the windows before drilling..some co's dont want to know
if you have drilled the windows then they develop a fault(i got my window people to sign a form saying it wont damage them by fitting vipers)if not glue them with a good quality glue..
I prefer self-adhesive, single cable trunking. Available capped or uncapped.
Wether you glue it, seal it, staple it, you will still see it. Trunking gives more professional appearance in my view.
;0)
If you don't know......ask.
Why are you fitting wireless and wired ?
a wired wire free system...i thought i was a decent engineer as well :no:
Guest Daznsaz
20891[/snapback]
It is just a cost cutting measure, most of the windows have two openers, if i used only wireless it doubles the cost of the contacts. I am going to use one wireless on one opener, then via the aux contact use a wired on the other opener. so it costs £28 per window instead of £50.
cheers for the advice so far.
glue seams the best option at the mo.
