Add Speech Dialler To A Honeywell Ag6 Sounder
blinkysiren
hello
I would like to add for example a honeywell informa speech dialler but could i connect the wires from the dialler to the terminals inside the Ag6.
This would make for easier in this instance to connect the phone line to a suitable point in an upstairs bedroom where the dialler and phone point are
thanks
blinkysiren
You would need connections between the panel and the dialler for it to work.
Power, tamper, plus trigger(s), so an 8 core between should suffice, don't forget a bb filter if required to.
Not recommended to take power etc from the sounder.
