JonAlarms Posted October 5, 2012 Posted October 5, 2012 Hi all, Have an LED question about the Vipers. Two Vipers are looped on one circuit - only one of them flashes. There is another viper on its own circuit, it was flashing but has now also stopped flashing. Did a walk test, and the sensors are working fine. Even set the panel and showed the customer they work fine as when the frame is knocked the alarm goes into alarm. Any ideas? Did notice, if i remove the power on the two which are not flashing and reconnect they flash, but only for a day... Weird? It is Euro Mini Panel Thanks
Oxo Posted October 6, 2012 Posted October 6, 2012 Doubt it. Anyway, although I presume its an older system. Turn the led`s off except for FTA. Sorted.
StevieV Posted June 27, 2013 Posted June 27, 2013 I get this a lot on newer Viper GL's - we are forever sending them back to ADI
arfur mo Posted June 28, 2013 Posted June 28, 2013 Hi all, Have an LED question about the Vipers. Two Vipers are looped on one circuit - only one of them flashes. There is another viper on its own circuit, it was flashing but has now also stopped flashing. Did a walk test, and the sensors are working fine. Even set the panel and showed the customer they work fine as when the frame is knocked the alarm goes into alarm. Any ideas? Did notice, if i remove the power on the two which are not flashing and reconnect they flash, but only for a day... Weird? It is Euro Mini Panel Thanks you can reset the LED by dissing the power to them, where you have 2 or more on a zone (bad news imho), use triple eol or fit link between them. that way 1st to alarm indicates (explained in the leaflet). If you think education is difficult, try being stupid!!!!
