Bpt Ophera
Amps
I have a faulty Ophera handset to replace on Monday on a system that also has three other Opheras. Anyone know if i can i just swap the faulty unit for new or do i have to relearn all the Opheras as if it was a new install?
Just swap
Have you proved it?
Swapped it with a working one?
Been caught out with that once,
Swap for another and then if working order new.
If you have done the above then ignore me.
PS the PSU about a "mile" away may have dropped output, seen that before.
My mistake, I was thinking of Nova's
