Castle Caretech Euro 46 Problems
Ms security
Thanks for the replies, last thing any ideas why when I replace the tranny it takes upto 24 hours befor it goes again?
Heat?
Mark, what cabinet size is the product ?
Post a list of every item powered by the system (bells keypads, sensors expanders ect ) inc quantity & make & model ?
Heat?
Thats stupid idea. if he hasnt taken commissioning readings why would you exspect he did/or is about to do a SDP.
Customers!
Well it could go either way, either I'm going to be really helpful & nice & add up what the current used should be & highlight the short comings in constructive helpful way & make JW proud.... or I'm going to rip the pee & make JB proud, time will tell!
anyways, transformers rarely fail if they do its either poor manufacture or there working constantly hard, to kill 2 in 48hrs must be some sort of record ?
which has been working fine, recently the panel went dead
Anyone, well most would check the logs. Get out a meter and check, test and check. Not just replace a board or a PSU.
Then call Tech?????
There is something dragging the panel down and a SDP is not going to make an iota of a difference if it has been working for months.
He has replaced bits and it still dies.
Come on, use some common sence here.
Something has changed, taking a voltage reading means sod all in this instance.
It needs a MA reading from the PSU onwards, the current drawn everywhere, then some totals being made.
Also all power connections being checked for poor terminations, a stray strand. EVERYTHING needs checking. Not as if it will take long for gods sake.
This smacks of not being , no...........I`ll leave it at that.
Jeff said it better.
PPinst.
I'm going to try and get that into some job sheets on takeovers if I can..
