Help With Scantronic 9651
grantsteve
Hi,
Hoping someone can help. We've had a couple false alarms during the day for the past two days running - both in the same zone. I'm starting with basics and trying to establish what zones relate to which rooms in the house, and see if I can work out what is triggering the sensor. Unfortunately I can't find original user manual and don't know if installer noted down which zones relate to which rooms. Is there anyway to find this out? I've tried doing the walk test but the panel only displays the room names and not the zones! I also thought that if I went through the event log and pressed the tick key when the activation record was displayed would give me details of the room, but no, just the zone.
Thanks
OK, specifics may help a bit here and perhaps my original post was a bit confusing. Zone 2 is being triggered, but I have no idea which room in the house is Zone 2. When I do the walk test the panel will display hall, lounge, kitchen, etc but no zone numbers.
Right, thanks. Was hoping it could be done without triggering alarm but guessed right first time so not too bad.
Absolutely no idea what is triggering the sensor, went yesterday after alarm was set for 2 hours after we left for work, and today was 5 hours after setting in the morning. After going all the way through the log, all the false alarms we get are in same zone (lounge).
Where to look first?
Dont be tempted to open the main panel, there is mains present and most likely on engineer reset for tamper.
Who installed it?
Why not give them a call?
How do you know zone 2 is the lounge now?
