D4v3y_S Posted November 20, 2012 Share Posted November 20, 2012 Hi guys, Having a very strange problem with an SD1 speech dialler and was wondering if anyone here could chuck some ideas myway. Right, Iv recently installed a Veritas R8 into a domestic property, connected to this which is triggered off the bell output is the SD1. When i was finishing off the install i couldnt get the SD1 to dial any of the numbers id programmed into it which i found strange as iv installed many of these in my 8 years experience in the trade and as many of you guys know on here the SD1 is simple, reliable and almost has a plug and play quality. So then, i did all the usual checks Line volts, filter, connections, voltage etc with still no joy. Thinking it might have been a cable issue i disconnected it all, wired it directly in the phone socket, rigged 12v off a battery and manually forced the SD1 to dial out with a short accross negative and input A. Still nothing!!!!!!! The Sd1 was giving out all the signs that it was dialing but nothing i.e. keypad locking out and even if i connected a landline phone to the socket i was using i could hear the message being played. So now i was thinking there was a fault with the SD1. So over the last couple of days iv been taking my bodged SD1 which is cable tired to a battery around to other seperate sites to test it on there phone lines and low and behold it works everytime. Returned back to the domestic property this evening for a second attempt and Nothing, same symptons as before, i then came home connected it up and it worked perfectly. Iv done all the obvious checks, phone line can dial out, different filters etc. If anyone has any ideas they would be greatly appreciated. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/ Share on other sites More sharing options...
sixwheeledbeast Posted November 20, 2012 Share Posted November 20, 2012 SD1+? Can you dial out with a test phone at the location? Is it a standand analogue line? Broadband on the line? Wired after the master socket and after a filter if required? REN issue? Tried disconnecting all the other equipment from the line? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/#findComment-294669 Share on other sites More sharing options...
D4v3y_S Posted November 20, 2012 Author Share Posted November 20, 2012 Yes its an SD1+ Yeah i can dial out from that line with a test phone no problem, its just an analogue line and its the master socket. Disconnected all other phones and alarm equipment, same results. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/#findComment-294677 Share on other sites More sharing options...
PSE Posted November 20, 2012 Share Posted November 20, 2012 1 - Default the dialler, make sure its set to DTMF rather than pulse, and without pauses 2 - Is there ADSL / Broadband on the line, If so have you put a filter before the SD1 3 - Check if the phone line isnt on a home business tarif, Some use a 9 prefix depending on the hunt group they are on Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/#findComment-294690 Share on other sites More sharing options...
Oxo Posted November 21, 2012 Share Posted November 21, 2012 All basic checks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/#findComment-294692 Share on other sites More sharing options...
D4v3y_S Posted December 3, 2012 Author Share Posted December 3, 2012 Update!!!!!!Thanks for your advice so far guys Having tried everything recommended by yourselves and tech support i exchanged this SD1+ for another SD1+ and guess what? it still doesnt work down my customers phone line. So, for the past week iv tested it on a dozen different phone lines at different premesis and it worked everytime except.............. down another Virgin phone line. i find this impossible the believe that this SD1+ works perfectly fine down any phone line apart from a Virgin line????????? Any help would be greatly appreciated. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/#findComment-295649 Share on other sites More sharing options...
9651 Posted December 3, 2012 Share Posted December 3, 2012 21 cn? but there is no kiss off so cant see why tbh, its not dialing a barred number from that line or anything?? What happens if you send the actual test off it, ie not with a trigger wire,but test through the menu option. You normally hear the dallier pick up, dialing tone, dial, then play the message. It might give you a clue? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/#findComment-295652 Share on other sites More sharing options...
Oxo Posted December 3, 2012 Share Posted December 3, 2012 As above, use the test and listen to what happens. Although put one on a Virgin line not long ago and all worked well. ADSL filter, line in, line out and to phone/laptop. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/#findComment-295669 Share on other sites More sharing options...
breff Posted December 3, 2012 Share Posted December 3, 2012 Have you put a T in front of the phone numbers to force it to tone dial, if not it will pulse dial, maybe virgin isnt compatible with old pulse dialling?? Just seen that PSE advised earlier The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/#findComment-295670 Share on other sites More sharing options...
Oxo Posted December 3, 2012 Share Posted December 3, 2012 Never had to myself, but worth a try. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/33652-sd1-problem/#findComment-295673 Share on other sites More sharing options...
