Sd1 Problem
D4v3y_S
Yes, they are a little highly priced still.
Very reliable though I must say, But I have only used aboout a dozen of the SD3. All are still running just fine to this day.
I have looked at the V2GSM unit, But its Pyronix so wont be using that rubbish.
  • 4 weeks later...
  • 2 months later...
what line voltage did you have? had a csl cs2300 do same problem on virgin line and found it running out on a line that had 38v on - you can hear the tone and dial out, didnt show line fail but just failed to signal ARC. had to disable pstn in end.
  • 1 month later...
