Galaxy 60
BUSTER
Some help needed, Galaxy panels are not my norm but can do most things but stuck on a problem.
Galaxy 60 lost all programming and so having to start from scratch
System has two independent areas both have there own e/e and max keypad
Programmed all zones etc and enabled groups
Programmed the zones into there relevant group
How do I allocate each keypad to a group?
Some users can access both groups and others just one group - how is it set up so that the multi area users just enter that area and arm/disarm that area only?
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
58 keypads will allow selection of groups
You allocate the groups to the users in 42
Be careful with that 60, i've had a few like that over the last year. It means the on board battery is ******. Any total power down will result in the same issue,
System had been powered down a while
dont group the rkp's,the users who have access to both groups need the star added to the group function in codes they will unset the group which the entry door is progd to by using their fob,they will have to unset the other group by presenting the fob again and select the group to unset,you might want to group the ee horns in 53 so they dont annoy the other..
All sorted, thanks, what a poxy idea with the non replaceable on board battery
Not sorted!
I'll go through the settings I have programmed
Allocated zones to relevant areas ( 1 or 2)
Menu 58 - Keypad - Groups - Put one keypad into group 1 and the other into 2 - pressed * to restrict setting unsetting the area to that keypad
ie Groups>A*_2__
Menu 63 - Options - Max - Max Parameters
Select max reader (either 10* - Keypad in area 1 or 11* - Keypad in area 2)
Max Group - select group
ie A_2__
Menu 42
Groups
Select groups 1 and 2 and *
What am I missing?
