james.wilson Posted December 8, 2012 Posted December 8, 2012 The manager code will always want to set all areas. Setup a user code with restrictions for arming securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Amps Posted December 9, 2012 Posted December 9, 2012 The manager code will always want to set all areas. Setup a user code with restrictions for arming I suppose i'll have to try an explain that it is still ok to set the the whole system with his code but if setting the garage only he must use a fob
james.wilson Posted December 9, 2012 Posted December 9, 2012 no you can use a code but i wouldnt use a manager code just add another code with restrictions securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Amps Posted December 10, 2012 Posted December 10, 2012 no you can use a code but i wouldnt use a manager code just add another code with restrictions Yes i get this now, although i have already told the customer you can use the manager code but now i will have to tell them you can but not if you want to set only one group. I cant believe that you can not set up a keypad to set only one area regardless of the code/fob used. Having used Galaxys on and off for nearly fifteen years i respect how useful they can be but at the same time i despise the over engineered ****.
james.wilson Posted December 10, 2012 Posted December 10, 2012 You can use a manager code but it will offer group choice. As you don't want this then don't use a manager code. You could always change the current mgr code and program the code they think is a mgr code as a high level user code with mgr access and restricted groups securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
