PeterJames Posted December 12, 2012 Posted December 12, 2012 As the topic title says varPicEvents: TPicEvents;PicUID: Int64;PicName: string;InputsCount,OutputsCount: integer;Inputs: array[0..15] of TPicPin;Outputs: array[0..15] of TPicPin;// system threadprocedure OnPinMessage(Sender: TObject; const User: string; const PinUID: Int64; State: boolean; const DataType: TRCadDataType; const Data: string);varidx: integer;begin try // translate inputs to outputs idx:=(PinUID and $1F)-1; if (idx>=0) and (idx<InputsCount) and (PinUID=Inputs[idx].UID) then begin Inputs[idx].State:=State; Inputs[idx].DataType:=DataType; Inputs[idx].Data:=Data;
sixwheeledbeast Posted December 12, 2012 Posted December 12, 2012 Looks like C, what files does it come from?
PeterJames Posted December 12, 2012 Author Posted December 12, 2012 On 12/12/2012 at 21:30, sixwheeledbeast said: Looks like C, what files does it come from? Its not C Ive copied the below from the help file, I can program some of it but I am struggling to get my head round it. If I type // infront of a line the line is ignored A format specifier begins with a % character. After the % come the following, in this order: - an optional argument index specifier, [index ":"] - an optional left-justification indicator, ["-"] - an optional width specifier, [width] - an optional precision specifier, ["." prec] - the conversion type character, type The following conversion characters are supported: d Decimal. The argument must be an integer value. The value is converted to a string of decimal digits. If the format string contains a precision specifier, it indicates that the resulting string must contain at least the specified number of digits; if the value has less digits, the resulting string is left-padded with zeros. u Unsigned decimal. Similar to 'd' but no sign is output. e Scientific. The argument must be a floating-point value. The value is converted to a string of the form "-d.ddd...E+ddd". The resulting string starts with a minus sign if the number is negative, and one digit always precedes the decimal point. The total number of digits in the resulting string (including the one before the decimal point) is given by the precision specifer in the format string--a default precision of 15 is assumed if no precision specifer is present. The "E" exponent character in the resulting string is always followed by a plus or minus sign and at least three digits.
Rulland Posted December 12, 2012 Posted December 12, 2012 Wouldn't have anything to do with the mobile site 'last poster' by any chance?.
sixwheeledbeast Posted December 12, 2012 Posted December 12, 2012 It's some C derivative. Hence the comments on // That help file is in Textpipe.
PeterJames Posted December 12, 2012 Author Posted December 12, 2012 Hmm it is very similar I did a bit of C when I was at college but it wasnt the same as this, but it may be why I can understand some but not all. I will research C a bit more thanks Is the any C experts out there?
RichL Posted December 12, 2012 Posted December 12, 2012 is this off an apple machine? Originally said by Charles Babbage On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
sixwheeledbeast Posted December 12, 2012 Posted December 12, 2012 On 12/12/2012 at 22:09, PeterJames said: Hmm it is very similar I did a bit of C when I was at college but it wasnt the same as this, but it may be why I can understand some but not all. I will research C a bit more thanks Is the any C experts out there? I definitely no expert but slowly learning C++ at the moment in my spare time. From the information you have posted and a bit of research this should be useful. It's not Python, Perl or Ruby to write off some languages.
