Phil Mailes Posted December 14, 2012 Posted December 14, 2012 Hi, Does any one have a manual for an ADACS Access Control Panel, if not a diagram of the panel showing the wiring configuration? Thanks in advance
Phil Mailes Posted December 14, 2012 Author Posted December 14, 2012 I really do not know. The customer just said it was an ADACS system. In the same sentance they mentioned Chubb and Shorrocks. If you had an image of each controller I would probably be able to tell. Thanks
Oxo Posted December 14, 2012 Posted December 14, 2012 This is all I have for that in user manuals, its not common here Aussie IIRC. c1000.2000 user.pdf
Securitycomp Posted April 5, 2013 Posted April 5, 2013 Can anyone confirm if there is a UK distributor for Adacs?
mikeald Posted April 7, 2014 Posted April 7, 2014 the ONLY distributor for adacs is CHUBB. This is a cast iron guarantee. Intruder & Fire Member
Cubit Posted April 7, 2014 Posted April 7, 2014 the ONLY distributor for adacs is CHUBB. This is a cast iron guarantee. Bit of a random one?
BarryChi Posted May 3, 2014 Posted May 3, 2014 Mike's correct. ADACS was developed initially by Shorrocks, taken over by Initial and then Chubb. Their address is Shadswick Road, Blackburn, Lancs. I don't think you'll find them very helpful though. I've got a load of ADACS and ZMP information, but sadly only in paper format and not pdf. Good luck, probably best to leave the system alone or replace it!
BarryChi Posted May 3, 2014 Posted May 3, 2014 Don't know if this is of any use. Just bear in mind every site is customized for the particular client.ADACS to Oracle, to ZMP.pdf
petrolhead Posted May 3, 2014 Posted May 3, 2014 Every site is bespoke and because of the type of sites usually protected by that system its unlikely anyone involved will share the service info about it, usually companies that takeover end up having to replace the first time they have a software problem.
