Securit 700L
Guest rawlinson
Guest rawlinson
I have recently moved into a new house with a Securit 700L alarm. A coule of eveings ago there was a very short power cut and the tamper alarm went off. Ever since th etamper light has been flashing, I have been unable to reset it, and the internal alarm sounds when the full alarm is set.
can anyone help?
Its going to need a new battery and a service. Id get the yellow pages out.
Guest Peter James
Agreed with the above
Guest rawlinson
Thanks.
Until I can get somone to look at the alarm would there be any problem if I turned the alarm on (aside form the internal alarm sounding - does it cut out after a certain period of time?)?
Guest Peter James
Its hard to say without examining it. why would you want to if it dont work.
If its a case that you want the power on but not the alarm then remove the fuse from the spur.
Pete
Do as Pete says . But be prepared for the outside box to start sounding a few hours after.
Dave Oxendale
York based security systems engineer.
There's no point trying to set the alarm, as it just wont set with a tamper fault. It's goosed :yes:
