Galaxy A1 A2
danlad1980
i'm open to any ideas round it!
The op would have his say hall door in G1 (House), but have the option to terminate G2 (the garage) on the way out. He then selects 1 & 2 to 'S', out he goes, both groups terminate via the hall door. Comes back in the house, G1 is in entry and his code/fob will only unset this, even if it has both groups assigned to it.
The above is whats happening imo, and what i've had on sites in the past. The option is RKP in garage, open door garage entry door and fob that, or unset via Keypad in the house (which he's doing)?
aye, suppose you could use the on board relay to follow G1 set/unset then go from there. Bit messy though as a M series you could just have auto unset per code/fob as previously mentioned
ive just tried it on mine,user 4 assigned groups 1&2 no star in groups and entry dr as final with both group 1 only and 1 with *2,set with user 4 both groups set,start ent timer unset with code 4 both groups unset,thats a 504 not a dimension tho cant see it being a problem dont have a prox to hand but prog fob as per user code,should work imo..
