Christian Smith Posted December 25, 2012 Posted December 25, 2012 Hi all, i have a veritas 8 compact installed proffesionally by the previous owner,we have had the house at least 5 years .it works fine, apart from when the alarm is active, it sometimes goes off .i check the pirs thats activated to no avail, it will probably do the same thing a couple of weeks later but this time it will be different pir's can any one help please.ive checked the sensors for spiders etc sometimes when we have been out when its done it i usually presume its cats or somthing? when its happened when we are a sleep i usually come down stairs expecting the worst i check things out where its activated again no clues. i then usually re set it and go back to bed. i can provide more info if required kind regards christian
Oxo Posted December 25, 2012 Posted December 25, 2012 5 years needs a new battery, Plus a clean out of the defectors, bear in mind they may be on "Engineer" reset only. That is your answer, unless you have a persistent fault on one detector. But the battery is the first you need to replace. PS you have cats, kill them or leave them out or in a non protected room,
sixwheeledbeast Posted December 25, 2012 Posted December 25, 2012 Call the installer back for a service and explain your issues. If they are not available, contact an approved company and do the same.
james.wilson Posted December 25, 2012 Posted December 25, 2012 Yep as six wheeled. It shouldn't be doing that but if it hasnt been serviced for 5 years all sorts could be wrong securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
magpye Posted December 25, 2012 Posted December 25, 2012 I bet the battery has never been replaced. Merry Christmas. Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
Christian Smith Posted December 25, 2012 Author Posted December 25, 2012 I bet the battery has never been replaced. Merry Christmas. could the old battery be the cause? merry christmas I bet the battery has never been replaced. Merry Christmas. the battery has never been replaced but this fault has always happened since we got the house 5 years needs a new battery,Plus a clean out of the defectors, bear in mind they may be on "Engineer" reset only. That is your answer, unless you have a persistent fault on one detector. But the battery is the first you need to replace. PS you have cats, kill them or leave them out or in a non protected room, did you mean detectors? we dont have cats , what i meant was we have a pir in our concervetory if it happens to pick somthing up in the garden 5 years needs a new battery,Plus a clean out of the defectors, bear in mind they may be on "Engineer" reset only. That is your answer, unless you have a persistent fault on one detector. But the battery is the first you need to replace. PS you have cats, kill them or leave them out or in a non protected room, i agree abou the cats they **** in my garden
sixwheeledbeast Posted December 25, 2012 Posted December 25, 2012 the battery has never been replaced but this fault has always happened since we got the houseThis still doesn't rule out the battery is faulty. This would be the first thing to do. It could be the panel, sensors, wiring and induced AC ... the list continues. IMO a good company should find the problem. what i meant was we have a pir in our concervetory if it happens to pick somthing up in the gardenPIR's cannot see through walls or glass. Conservatories should have a better quality sensor due to the enviro. If the sensor in the conservatory is detecting the garden, it's a DT and not setup correctly.
sixwheeledbeast Posted December 25, 2012 Posted December 25, 2012 Battery. Is a song by Metallica....
