Rascal alarm fuse
Guest mike
I've got a rascal burglar alarm which was fitted well before I moved in. There's a battery fuse in it which has blown, what rating should the fuse be? The one which has blown is 250v T1, whatever that means.
Appreciate any advice regards
Batt Fuse - 1Amp (20mm)
Guest Peter James
It would of blown because the battery was drawing too much current, so when you buy the fuse get a replacement battery.
