Paul. Giles Posted January 8, 2013 Posted January 8, 2013 Just got called by our client as they were concerned because an electrician damaged one of our cables. They repaired it and managed to reset it but wanted us to double check it. Cable was joined in a 20A JB with the four terminals and connector blocks for the other four connections. Question is, would you go after the sparky to "inform" them of the error of their ways? If we were not informed by the client it would look like we had damaged it. Another reason for eng reset on tamper i would guess.!
jb-eye Posted January 8, 2013 Posted January 8, 2013 Just got called by our client as they were concerned because an electrician damaged one of our cables. They repaired it and managed to reset it but wanted us to double check it. Cable was joined in a 20A JB with the four terminals and connector blocks for the other four connections. Question is, would you go after the sparky to "inform" them of the error of their ways? If we were not informed by the client it would look like we had damaged it. Another reason for eng reset on tamper i would guess.! Paul You been around a while and im surprissed you even admitted diffrent. Back in my sparky days we programmed spare unused zones as 24 hour and always eng reset for tamper and they were cash weekend jobbies Customers!
itesecurity Posted January 8, 2013 Posted January 8, 2013 If Mr Sparky was confident that he fixed it right he wouldn't have asked for it to be checked by yourselves. He's a spark at the end of the day and I'm sure he doesn't have any 20 amp junction boxes with tamper connections in his van.
RichL Posted January 8, 2013 Posted January 8, 2013 Dont bother going after the sparky, you're wasting your time. Repair correctly, note on your docs that the damage was done by 3rd party and had been incorrectly repaired, charge accordingly, inform customer. Originally said by Charles Babbage On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
norman Posted January 8, 2013 Posted January 8, 2013 +1 Nothing is foolproof to a sufficiently talented fool.
alterEGO Posted January 8, 2013 Posted January 8, 2013 unless its a G2 Why? you can still use eng reset for tamper if you see fit, as we do. Jef: I used to prog spare zones as PA, the good old days
whistle Posted January 9, 2013 Posted January 9, 2013 All our systems are on engineer tamper reset, even bells only. More so wire free systems .
alterEGO Posted January 9, 2013 Posted January 9, 2013 All our systems are on engineer tamper reset, even bells only.More so wire free systems . You would be daft not too....................'I want to change the bats myself' 'no problem, good luck'.
