Honeywell G2 Or Enforcer For Domestic
It was KH only PA with a maint of 90 PA  plus batteries,
64 or something for I assume SIA with the panel doing the signaling so basically a digi.
Still, not sure I'd want the hassle for such a low amount of cash. Only equates to just less than £13 a month. I think you're right to walk away at that level.
Hello,
Thanks for the reply. If you did reply, it didn't make it to my inbox, I've attached a screenshot of your replies on Saturday. That was the last one i received.
You are correct that the keyholder monitoring is £60pa
post-44049-0-48444200-1358188792_thumb.j
Well I deleted all messages last night so it would have gone then.
I have a thing about keeping the in box empty.
Well you have the reply now.
And links for other companies, as above most charge more for a reset.
Getting hassle now, and not even fittted anything :D
Hello,
Although you may have deleted the conversation from your side I can still view the whole transcript.
Thank you for the reply above, I'll contact MRFS Group and arrange a survey.
The cost of the system isn't an issue, what I wanted when I started the process was a G2 wired system as it appeared from research to be an established and reliable system. The company in question we're keen to install a wireless system.
So, I'm still trying to find a local, non-national company, who are happy to install and maintain a wired system.
Hello,
That might be a difficult task. The main reason most use wireless is speed. Running cables neatly in a res is hard and takes time and usually the cost of labour makes the quote at a price someone is usually unwilling to pay. We do have a handful of hardwired domestics but the cheapest of those hardwired was £1500 with recur billing if £30 per month. This price point is way above what the average domestic will consider paying. Quite often I've seen people complain about the £4-600 price band.
Some are much harder than others but hiding cables, especially with these solid floors and laminate flooring makes wireless a much cheaper option.
Hello,
And so what if you can see the transcript. Publish the whole lot, what I have said is fair and was to try and assist.
So a veilled threat is nothing to me. Post away.
The companies mentioned are not Nationals.
Jist of conversation:
How much are your quotes and the companies.
I know someone who works your area.
I might, but need prices.
So what.
I also might know someone else who would consider, but now I cannot be bothered.
That's the other issue I don't like with res's, getting half the county to quote. We'll only do res for existing customers who are conditioned to our pricing and have already made a commitment to us.
I`m wondering about this the more I read.
I know the "covered" companies service manager. Might call him tomorrow.
As we all know its a small world here :D
