james.wilson Posted January 20, 2013 Posted January 20, 2013 Looks like its not programmable. But it sounds like your system isnt setting sometimes. WHat do you have your exit time set to? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
SoupDragon Posted January 20, 2013 Author Posted January 20, 2013 30 seconds for A and B, C and D aren't used. If the hallway or door sensor is trigered it will stop counting down with exit via front door/hallway and then resume counting down from where it paused when the sensors aren't being trigered.
Oxo Posted January 20, 2013 Posted January 20, 2013 Are you full or part setting when this happens? Have you tested it when set? As in triggered it. Might as well do it now had, next door banging and hammering all day !!
james.wilson Posted January 20, 2013 Posted January 20, 2013 I dunno then. But as above do you know its setting. When it set fails what else is in the log? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
SoupDragon Posted January 20, 2013 Author Posted January 20, 2013 Oxo both full and part produce the same set failed in the logs. I can confirm the alarm does trigger, tested it briefly earlier Here is one of the log entries James: 15:32:45 Exit started by (quick set area(s) A) 15:33:24 Set Failed (Area(s) A) 15:33:52 Final Set (Quick Set) 15:34:05 Entry time start
james.wilson Posted January 20, 2013 Posted January 20, 2013 It took over 1 min to arm. IS there a reason for that? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
SoupDragon Posted January 20, 2013 Author Posted January 20, 2013 Hallway detector is FX (ER in part). When it's triggered it pauses the exit timer with "exit via hallway" (same with the front door, but that's set as entry route IIRC)
james.wilson Posted January 20, 2013 Posted January 20, 2013 HOw long is your hall? 100m? You could try using final door as the setting type so it set quicker after you leave? But the panel is right it is failing to set in a reasonable time. Odd you cant edit the setfail timer though. I wonder if its exit time +50% or something? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
goncall Posted January 20, 2013 Posted January 20, 2013 not a panel ive ever used,but is the pir in the hall looking at the door,is the door final set,could be double bounce on the hall pir causing a set fail
SoupDragon Posted January 20, 2013 Author Posted January 20, 2013 HOw long is your hall? 100m? You could try using final door as the setting type so it set quicker after you leave? But the panel is right it is failing to set in a reasonable time. Odd you cant edit the setfail timer though. I wonder if its exit time +50% or something? Ah I've just tried changing the inputs with that in mind. I originally set the front and back room PIR's to ER (FX in part) as the folks like to come into those rooms before the alarm sets/unsets. If I trigger one of those PIR's whilst leaving then I get the error in the log. If I don't then the error isn't in the log. Looks like that's the problem! Not sure about the time + 50% but I can test it tomorrow with the hallway pir and see if I get set fails on that in the log. Is it wise to have set on final door?
