Guest rincewind128 Posted August 24, 2004 Posted August 24, 2004 Hey, Just wondered if anyone knows how to change the code on the optima xl4 system? We've worn out the buttons on the current code and I can't find the instruction booklet either in our house house or on the net anywhere. It's getting to the point where the alarm goes off because you can't put in the code quick enough (especially if your my nan) as you have to press each button about 10 times before it works so any help would be greatly appriciated. , Joe
Guest dale Posted August 24, 2004 Posted August 24, 2004 It might be easier just to get a new panel, with new buttons! If you are lucky there may be some engineers with a spare keypad membrane they can send you.
