angellonewolf Posted January 28, 2013 Posted January 28, 2013 hi my alarm panel has stoped working to give you a few details this where it gets a bit where i am having to have a think i installed a new battery in to the alarm panel in the morning powered on and all working fine went out and set the alarm come back later on in the night after the storms and the lightning the panel is off no power 2 fuses on the panel are blown and if you replace the fuses you get a burning smell and a very small amount of smoke i am thinking the board is well gone lol ps asking around there are meny problems with alarms and peoples telephone lines so i am thinking that its a lightning strike or such.Round the corner on the bt tel pole the bt box is missing the cover and the wires are every where in the bt box inside the are black marks in and around the socket any help please i am going to buy a new panel in the morning thanks for your help inadvance my question is ps i cheaked the conections on the battery and yes before you ask they are on the right pos and neg i did cheak twice before powering on
Oxo Posted January 28, 2013 Posted January 28, 2013 Fit new panel and a anti surge protection kit , that hopefully will blow and save the panel. Unless it is a cheap panel and then it might be cheaper to just replace the panel of it happens again, had one site hit 4 times! Ps does your phone work or are you using a dongle?
angellonewolf Posted January 29, 2013 Author Posted January 29, 2013 internet through virgin only a cheaper OPTIMA G3 or g4so £55 to replace as long as hasent taken out any more i hope the dialer is ok but if not have had 12 years out of it so cant moan
Oxo Posted January 29, 2013 Posted January 29, 2013 Well if its come down the phone line the dialer is stuffed too. Tried a test call?
angellonewolf Posted January 29, 2013 Author Posted January 29, 2013 cant try a test call as there is no power as the alarm panel is down so untill i replace that i cant see if the dialer is bust or not
Rulland Posted January 29, 2013 Posted January 29, 2013 Power the dialler from the new battery to test.
angellonewolf Posted January 29, 2013 Author Posted January 29, 2013 am going to have a go in the morning will post back when i get any more info thanks angel
sixwheeledbeast Posted January 29, 2013 Posted January 29, 2013 Be careful you don't blow your new panel with a blown speech dialler. As above test on a battery first.
morph Posted January 29, 2013 Posted January 29, 2013 Do you actually know what was wrong with the system before you started? What made you change the battery?
