Advice On Installation Location
Hi,
Recently moved house and want to get alarm installed asap.
I have a texecom veritas excel control panel and would appreciate your advice on what to consider when choosing where to install it....
Can I take a fused spur off a lighting circuit and install the pcb in the loft? Is it better to spur off ring main?
Would it get too hot in the loft during the summer? (Ignoring last summer's weather that is!)
I have an airing cupboard so could install in there, but would that also be too warm?
I would like to have a contact on the garage door but found I had a few false alarms using a surface mount door contact on my last house and ended up having the double knock feature on to reduce the false alarms. Is there a better alternative?
Any other tips would be greatly received also.
I don't think I'll have any issues with routing cables as the floor boards will be up and the plasterboard is dabbed onto the walls so I have a void to fish them down if needs be.
Thank you in advance..
James
  • Replies 31
  • Views 4.3k
  • Created
  • Last Reply
Understairs cupboard, attatched garage or built in wardrobe are some of the better places for the end station. As you mention, there can be issues with the temperatures of lofts and airing cupboards which will upset the battery. Mains supply ideally needs to come from it's own MCB in the consumer unit, however there's no problem with spurring off the ring main. I don't see a major issue with coming off the lighting circuit but others would probably disagree. There's nothing in 7671 to say expressly that you can't.
As for false alarms from a door contact, unless it's faulty/badly terminated or the door can move enough when locked then you should not be getting false alarms from it. Could have been a cable fault too. NEVER double knock a contact as the door would have to be opened, closed then opened again for the alarm to trigger! Double knock is a bodge at the best of times but is absolutely never suitable for use with contacts. Find the fault rather than mask it through the programming. You can get specially made "heavy duty" contacts that are sealed and made from metal which are suitable for garage doors. You'll also need a 6 way junction box to terminate it in.
Edited by antinode
Trade Member
Hi,
Can I take a fused spur off a lighting circuit and install the pcb in the loft? Is it better to spur off ring main? You can so long as you are competant, personally though the ring main is a better choice if the bulb blows on a lighting circuit the trip will go too.
Would it get too hot in the loft during the summer? (Ignoring last summer's weather that is!) Will be cold in the winter and hot in the summer this will expand and contract on the pcb I would find a cupboard somewhere
I have an airing cupboard so could install in there, but would that also be too warm? The temp will be more constant
I would like to have a contact on the garage door but found I had a few false alarms using a surface mount door contact on my last house and ended up having the double knock feature on to reduce the false alarms. Is there a better alternative? There was something wrong with A the contact or B your fitting, there are millions of contacts out there that work perfectly well
Any other tips would be greatly received also. Dont pee up wind in a storm
James
Spikes from switching lights on and off?
Horrible interference with energy saving bulbs?
Use a heavy duty (shutter) contact on your garage door.
Double knock on a door contact? That will sort it :proud:
Ask the burglar to close the door and open it again though otherwise the alarm won't do much.
It's got to be a pretty ***** panel if it doesn't like lights being switched on and off! I'd say there were much 'dirtier' things, electrically speaking, on the ring main. Just my opinion.
Trade Member
Agreed although its not specifically banned, I'd feel as if I'd done something rough not putting it on the ring main or dedicated breaker.
Edited by matthew.brough
Aren't those energy savings one nasty and noisy?
Even so, not so great if turning the lights on zaps the alarm?
