matthew.brough Posted February 1, 2013 Posted February 1, 2013 you're using a **** toner then mate.. I prefer inkjet personally . . . www.securitywarehouse.co.uk/catalog/
Oxo Posted February 1, 2013 Posted February 1, 2013 I prefer inkjet personally . . . One more like that and you`re being deleted
james.wilson Posted February 1, 2013 Posted February 1, 2013 as above the ..... is doing my head in securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
goncall Posted February 1, 2013 Posted February 1, 2013 No you don`t. Not if you know how to use it correctly. But you do need the meter to take the readings after maybe not if strung across a ceiling,but in loomed cables on a long run there useless unless you undo the loom,granted ok if fault is at the start or end,but cant be trusted 100%,i would like one of those bt tdr's now thats a bit of kit.. you're using a **** toner then mate.. its a bt one,like i say great for single cable,but in a factory with loomed cables its hard work when tracing.
Ronnie Posted February 1, 2013 Posted February 1, 2013 i see where you're coming from now. i don't generally use it for tracing but for identifying ends. did a cctv upgrade recently, around 80 cameras and toner was the best bit of kit in the world for tracing disconnected cameras as all cables were lablled but no paperwork anywhere to explain the cable id
matthew.brough Posted February 1, 2013 Posted February 1, 2013 as above the ..... is doing my head in Gotcha. Didn't know it annoyed you. Apologies. www.securitywarehouse.co.uk/catalog/
Oxo Posted February 1, 2013 Posted February 1, 2013 Well I was on a job with two other engineers from another company and they were metering out cables all morning untill I sussed what they were up to and gave them my tracker. We had 50 odd circuits IDed in half an hour or so. All in a "loom", and each was spot on . Yours is either sh1te or your not using it correctly, and before it starts no insult intended. Just seen the added as I type this. I use it for a general cable if needed, and a certain trace also when needed.
goncall Posted February 1, 2013 Posted February 1, 2013 Well I was on a job with two other engineers from another company and they were metering out cables all morning untill I sussed what they were up to and gave them my tracker. We had 50 odd circuits IDed in half an hour or so. All in a "loom", and each was spot on . Yours is either sh1te or your not using it correctly, and before it starts no insult intended. Just seen the added as I type this. I use it for a general cable if needed, and a certain trace also when needed. never read the instructions tbh..
