Veritas Excell Rkp Problem, Please Help
sscottm99
I powered it down again, disconnected the battery (12.8V) and reversed this process a couple of times and the same thing is happening.
Souns like you measured the battery with no load being taken off it. Repeat the test with mains off plug the battery in and you will probably find it is low. In every case where I have come accross this the panel beeping its the battery thats no good. You usually find that the panel wont switch back to the mains power. Entering the code and trying to set it (mains and battery on) will usually sort the beeping out but not if the battery is duff
woof
