Risco Wisdom - Follow Me Function
jamesr1976
I have installed my new Risco Wisdom panel.
I dont seem to be able to get the Follow Me function to work - can anyone offer any advice further how to set this up and test?
Thanks
Thanks
Hi. it''s been a long time since i fitted one but from memory. you need to enable it in the engineer menu. Then i think the numbers are programmed from the user menu. As far as i can remember you cant reprograme the message. if not i will dig the manual out tomorrow.
Thanks for the prompt responses,but how can i test that it works?
When you say 30 sec delay? the alarm has to be activated for 30secs before the follow me message is sent?
Look in the index for "Follow me".
You need to turn it on in two places IIRC, the assign a "Partition" to it.
Command 5 6 02 turns it on in engineering.
Now have a read thru, no point not understanding and just being told. :D
