Psg Dome Cameras
Busta
Hi all,
I am installing a 5 camera, DVR CCTV system. The client wants internet and smart phone access. I am thinking of getting these cameras http://psg-info.com/cameras/psg1002irw and this DVR http://psg-info.com/dvrs/8-channel-dvd/psg208.
Has anyone used PSG cameras/DVRs before? are they any good? Are there any decent DVRs that anyone could recommend for about £500? Same goes for the Dome cameras.. about £130 each.
I used to install Vista/samsung cameras and Dedicated Micro DVR's years ago. Are they still any good?
Any help would be appreciated ;)
Si
Thanks for the reply. Do you run cat 5 for these cameras, or do you use the coax and BNC's? Are the 002's any good at night without lighting do you know? The reason i went for the 1002 was for the LED's as the house I am installing them in has no external lighting. I might buy a different DVR as no one seems to have any feedback on the PSG one. Any recommendations?
Thank You
We use the Alien dvr range from SystemQ .
You could use either cat5 or coax shotgun .
Last install I did I used cat5 and twin shotgun cable but it's up to you.
Would go with the IRs if there no lighting at all.
Have used the 002 PSG in past they are good value for the spec and the built in balun is usefull
Work well in low light but like all  on slow shutter you will end up with blur
Fit a seperate IR illuminator to light the area or sell them a lighting solution like GJD
DVR for domestic we have been using Adata QVIS iApollo work well and easy to use
  • 6 months later...
