I Need To Automatically Generate A Email
mcelec
Not sure this is the right place to post this, I want to be able to generate a email from a input, someone has mentioned Rasberry Pi, I have never used it but it does seem like it may be a option, so here is the scenario that I want to achieve:
Relay operates and generates signal.
The trigger generates a email that is forwarded to a pre set email.
Any ideas?
I suppose it all depends on the requirements and if the customer will allow you to develop / debug your solution on-site.
For an off-the-shelf installable solution, you can use a Galaxy G2-12 panel with low cost IP module.  This can be linked to £1/month monitoring which gives the advantage of accurate panel logging, battery backed PSU, polling, Web Interface and web configurable SMS / Voice / E-mail. It would also give future expansion capability for further signal monitoring from other outputs.
You could always stick a prebuilt turnkey linux build as a VM for test purposes - of course there are security considerations with doing so in anything but an isolated network.
We have Vmware VSphere and all the common distros are on there so I'll have a play with a pi and ubuntu with the GUI first and see how I get on.
Still feel a little uneasy about not being a Microsoft Monkey but it's time I took the plunge.
Any ideas?
You could do worse than one of these
http://www.axis.com/products/cam_p8221/index.htm
It will send an email on alarm but not monitored so just like a speech dialler or text dialler in effect
VSphere supports all the common distros but does not include them - the selection on there is for startup/shutdown and drive mounting compatibility.
The releases are easily sourced though and as others have said go for a GUI interface to start with, it really is not that bad and I can assure you that for every single Windows feature you find lacking in various Linux builds you will find another feature that you will think 'I wish Windows had this'.
Also there is plenty of good Linux community support if you know where to look.
Could you post some links please? i would be very interested in them
Am i missing something here? Webway ip or gprs or even Dualcom and a PSU.
What more do you need? Maybe a few bits depends what output the plant has. No need for a panel etc though.
Useful sites/pages I have bookmarked.
https://www.linuxquestions.org/
http://www.tuxfiles.org/linuxhelp/
http://www.computerhope.com/unix.htm
http://ubuntuforums.org/
Most big distro's have there own IRC channel on freenode.
Login with mIRC, Pidgin, Irssi or whatever and ask away someone will help.
https://www.freenode.net/
