Texecom Premier 24 Walk Test
Ctaylor
Just wanted to back up your point :-
Thanks.
Think its been proven too,
Someone else just told me about the caps. I thought it was just the flappy caps damm might be hard to get them back out.
Baffled as to why this isn't mention in the manual.
Distorted ? What do you mean
" I bet this is like pulling teeth for you pros" do apologise.
What makes you think we read the books?
But it was obvious.
We do read the books.
After we have had a play.
Only way to learn :D
Ps I've been reading this manual over and over think I've done well so far considering I sit in an office for my job and haven't done any electrics before.
No the back plate is all good. Just these Invisible plugs that have caused me this problem.
Hopefully it will be as obvious as you say when I take it down tomorrow.
All done well bar turning off anti code!!
Thanks for all the help. Turns out the mapping was done on rkp 1 (doesn't exist) and my rkp was 4.
You don't need to turn off anti-code
You need to remove the Confirmed Reset option in Area Options.
Then nothing will be set to cause the anti-code.
