Connecting smokes to Scantronic 9448M
Guest gowron
Guest gowron
Hi everyone,
I'm not an installer but is was wondering if anyone can answer this question:
I have a Scantronic 9448M control panel to which i like to connect two smoke detectors. The smokes deliver +12V on their status output when triggered. Zone 5 on the panel can be programmed to be used for fire alerts. Now for the question: How can i connect these detectors to the zone input of the control panel? Do i need some sort of relais between the detector and controlpanel?
If you know the answer please let me know (with a small schematic?) :)
Thanks in advance
Eric
Eric are these specific security system smokes or general ones.
Dave Oxendale
York based security systems engineer.
Guest gowron
21676[/snapback]
I think their normally used with fire panels and security systems. I don;t know the exact type but they are from Ajax (hexatron or something like that). They look rather professional.
Im not 100% sure but i dont think these are compatible with the 9448. I always use the exodus range from texecom.
Dave Oxendale
You need 12v versions with a normally closed connection
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
you could use the 12v output to drive a mini relay with the nc connected across the zone
Guest gowron
Thanks guys,
i think i will dump the ajax smokes and go for the texecoms
