matthew.brough Posted February 21, 2013 Posted February 21, 2013 Where does my IP suggest I originate from? www.securitywarehouse.co.uk/catalog/
james.wilson Posted February 21, 2013 Posted February 21, 2013 Where does my IP suggest I originate from? your use 3 for your mobile securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
matthew.brough Posted February 21, 2013 Posted February 21, 2013 That's when I'm on the ipad. I think when at work the location is very accurate. www.securitywarehouse.co.uk/catalog/
Amps Posted March 15, 2013 Posted March 15, 2013 Back onto the subject of setting groups on a Galaxy. If a keypad has been programmed so that it is restricted to group 2 only (using the * ) and the manager code is entered, will the manager code override the restriction or will the manager code only set group 2 ?
james.wilson Posted March 15, 2013 Posted March 15, 2013 On the proper gals a manager code will have group choice regardless of group restriction. Not sure on the G2 never used them in a proper group environment. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Amps Posted March 15, 2013 Posted March 15, 2013 On the proper gals a manager code will have group choice regardless of group restriction. Not sure on the G2 never used them in a proper group environment. Ok ta. Proper gal G3 & Dimension? One other thing that i cant seem to get me head around with Galaxy, the Dimension range is that grade 3?
james.wilson Posted March 15, 2013 Posted March 15, 2013 Ok ta. Proper gal G3 & Dimension? One other thing that i cant seem to get me head around with Galaxy, the Dimension range is that grade 3? Proper gals are classics, G3 and dimensions. Dimensions are grade 3 yes securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
goncall Posted March 15, 2013 Posted March 15, 2013 Back onto the subject of setting groups on a Galaxy. If a keypad has been programmed so that it is restricted to group 2 only (using the * ) and the manager code is entered, will the manager code override the restriction or will the manager code only set group 2 ? your better off grouping the user codes and ee horn outputs rather than group the keypad in 58 i find,the manager code will always be set for all groups you cant take that off,tho you can take the * feature off the mgr code so it stops group choice it will then set or unset all groups
Amps Posted March 16, 2013 Posted March 16, 2013 your better off grouping the user codes and ee horn outputs rather than group the keypad in 58 i find,the manager code will always be set for all groups you cant take that off,tho you can take the * feature off the mgr code so it stops group choice it will then set or unset all groups So it seems. I would of thought restricting the keypad for group two would of worked with either manager or the user codes. Typical Galaxy though as it aint that simple as the manager code will set all areas even though the keypad is restricted to group two only
